I've recently moved into a property which has a combination boiler. The boiler has been working well, I had to drain the radiators, after that the boiler was still working without fault. Only recently has the boiler been leaking. It leaks from the underside, from a hole, its not a lot of water but it is fairly constant dripping.
The other day (after it had started dripping) the isolator fuse went on the boiler; I replaced this and the boiler worked again. There is nothing obvious causing this dripping and it doesn't appear to be stopping the boiler from working but I am just concerned because it obviously isn't right!
Any advice would be most welcomed.
The boiler is: OPTIMA 701, FERROLI.
Thank you
Thank you
