Leaking conservatory gulley/gutter joint
1 Nov 2004
A small leak has developed in the corner of my conservatory which I suspect is caused by a failed gulley (metal) to plastic gutter joint which is currently joined with a grey sealer. The conservatory is is about 6 years old.
What is the best approach for fixing this or should I go back to the installer? I have considered Spray 'n' Seal or Rescue 911.
John
Forget any type of spray sealer, it needs to be removed/replaced/refitted. You could go back to the installer and see what they say, I don't think they will be very helpful after 6 years.
Andy
OK Thanks Andy.
Please can someone suggest what is the best sealant to use when remaking the joint?
John
