- Joined
- 29 Jan 2007
- Messages
- 40
- Reaction score
- 0
- Country
Gents,
I have noticed what I've called an isolation valve which feeds the WC refil unit leaks. I thought it was something simple like a replacement seal however on putting a new unit it I've noticed the problem seems to be a bit more annoying! If you look at the attached image, in particular where the screwdriver is pointing, this is the part of the valve where the water seeps through. Although it looks like a solid body I've noticed it seems to be threaded, I came across this by accident when tightening the bolt above the screwdriver position. I can't really see how to tighten that area. Can you advise on the following;
- What do I need to do to stop the leak?
- What parts will I need and what should I ask for? I went to my local B&Q but had little success.
Many thanks in advance for your assistance, Kevin.
The screwdriver tip is pointing at the point where the water seeps out.
