leaking plastic and polystyrene flush system
2 Jan 2010
Kent
Hi and sorry if this has been answered before - I have searched but found nothing similar.
I have a slimline toilet cistern. The flush mechanism is all plastic and the ball valve seems to be polystyrene which can be adjusted by screwing it up or down a plastic screw.
The cistern started leaking into the bowl this morning via the overflow. I've had the cover off but being a complete beginner don't know what each bit is for and what to do about the leak.
Any advice would be really appreciated.
Thank you
Thanks Dan - any idea where I can get a new polystyrene ball valve?
sorry - another question - any idea how I can take the old one out?
Turn the water off and undo the nut and back nut that hold the pipe to the valve and the valve to tge cistern - assuming it is side entry.
But you are entering the territory of "if you have to ask, you shouldn't touch ".
Ah - OK then... thanks for the advice.
Didn't want to have to call the professionals but guess I should then.
Cheers Dan.
