- Joined
- 3 May 2020
- Messages
- 42
- Reaction score
- 2
- Country
The strap boss below was fitted about 18 months ago for a Combi Boiler outlet and connected to a pre-existing down pipe which I believe is our upstairs neighbours' (there are 2 flats above) wastewater pipe. Worked fine for a while.
As you can see in the photo there is now leakage coming out - the leakage is from the rubber gasket/plug rather than where the strap boss meets the downpipe, that seal seems solid. I've tried re-seating the rubber but it keeps leaking - my assumption is the velocity of water falling down the main pipe is pushing against the the rubber causing it to come loose.
Any suggestions? I have Plumbers Mait, will that help?
