Hi all,
I have recently re-furbed a tired bathroom and am quite impressed with the result.
However i have just noticed a leak which eminates from the basin waste / soil stack boss connection.
The boss is an 'in-line' version ie it is part of the stack and not a strap on version.
The leak seems to occur when the tap has been switched off and seems to work back up the underside of the 32mm waste pipe.
The waste is pushed into the boss and is supposed to be sealed by a rubber O-ring and plastic grommit of the boss.
This is exactly as the old system was set up, I simply pulled out the old pipe and pushed in the new so i don't understand why it is now leaking?
I am fairly sure the new and old pipe are the same diameter however the fitting / connection isn't particularly tight.
Is there another gasket/O-ring/washer I can purchase to solve this or is it a bigger problem??
Many thanks in advance for any advise. I appreciate there are similar posts but they all seem to be about the strap on version..
