leaking worcester 9.24E
20 Feb 2008
Hi Guys.
Came home to find my boiler leaking. I know its getting on but its been very reliable and serviced yearly.
The leak is coming from the isolation valve on either the flow or return. ( its the valve which does not join the cold inlet with the filling loop). Its leaking a few drops at the moment but i dont want it to get any worse.
So, is there a way of repairing / fixing this leak. Or is it best to drain it down and install another valve. If so, where can i get one from please.
Many thanks.
Josh
Thanks clf
Its leaking from the middle of the valve - the bit you turn with a screwdriver to isolate. Is replacing the washer going to stop it leaking from there??
Ok, but where do i get a replacement valve from for this boiler??
Many thanks
Any idea of the part number i require.
josh.
PS: this site it just great :D
done one today its a right pig of a job. got to take pump off, remove pipes just to get to floewreturn connecting manifold.
Hi there,
I have the same problem with my 9.24 boiler. I need to replace the bulkhead valve. I tried my local HRPC today and they told me I was now unlikely to be able to source the part.
Anyone help with a part no. so I can Google it?
Many thanks
Alistair
