Probably a simple one, isolator valve connecting to the plastic screw threaded (Getting technical here, sorry......) bit that goes through the cistern.....is leaking.
Should I use PTFE? it's wierd as it looks like it is trying to compress onto the plastic pipe.......
should there be another seal in place? The whole thing is at a rather dodgy angle which means the joint between the 2 is always under external pressure so I'm concerned it might need bending to line up correctly before trying to stop it leaking........
help!
help!
