Leaky radiator
9 May 2007
Newcastle upon Tyne
Hi
I have a tiny hole in radiator and cant afford to get it fixed at the mo.
Can anyone tell me what to buy that will seal the hole till I can afford to get garage to fix it.
cheers
x x
Radweld will do as a temporary fix and can get it at most petrol stations
agree with neo - radweld for a small leak
if this doesn't work then drain it down while hot (be careful) so that all moisture evaporates from the hole and coat it with a dollop of araldite. refill it after 24 hours and see how it goes. at the least it should slow the leak down so that radweld can manage it.
JonB said:
Try a couple of EGG WHITES, an old trick which works sometimes.
What ever you do, dont do this :lol:
It's alright if you're stuck in the desert and have to get back to safety. but it'll cost you a fortune to have the omlette removed from your engine, radiator and heater matrix
