leaky sandstone barn
22 Jan 2009
Cumbria
Hi can anybody give me any advice on which way to turn next? I renovated a sanstone barn and to keep the lovely sandstone on show spent a small fortune having all the joints raked out, pressure washed and re pointed (weather struck style). I then sprayed the sanstone with an approved silicon sealer, Fine until approx 2 years ago after serious storms water appeared to be running in and ontop of and down the side of the plasterboard reveals on all the east facing windows and doors. I repaired any cracked looking pointing and re siliconed which seemed to work for a while but it started again. I then filled the sandsone with a waterproof grout to try and solidify the walls and prevent any more water ingress, this hasn't worked either :cry:.I am at the stage where i think rendering the whole face is going to be the only option but i want some thing that is going to be very water proof still asthetically pleasing to the eye and not require painting every year. does anybody have any advice on any products or specialists that they have possibly used on a sanstone barn conversion as i can't afford to throw much more money at this problem any info will be gratefully recieved.
Regards.
all that silicone sealer may make rendering a bit awkward. :eek:
re-skin the barn in brick. :idea: :p
You would have been better off repointing with lime mortar and not treating the stone, that way the structure can breath, at the moment water is finding its way in and can't get out through the cement/silicon.
Jason
HI
Sorry for the delay had a kingfisher water proof specialist up the render will be ok to go if the sandstone is tanked first not ideal for price but guaranteed! As for bricking up planning would not allow it thanks for the thoughts :)
