LEC under counter fridge with freezer box.
25 Apr 2019
Hi all, hoping you can help me.
The LEC fridge I purchased only works when the weather is warm, when I contacted LEC they said I should have read the instruction book, this book was in the fridge when it was delivered.
I have it in an outbuilding where it only worked last summer, this is no good as I need to keep some bird food frozen to feed all year round.
My query to you good people is can the fridge be altered to work in any ambient temperature or is it fixed to the factory setting.
Regards Brian
A FRIDGE should not freeze anything apart from in the icebox section. Are you saying the temp. never drops below zero in the ice box section with the fridge stat set to the coldest setting? If so you could try covering it with an old quilt or thick blanket.
