    Dismiss Notice
LED Beam Angles
Discussion in 'Electrics UK' started by BGEngineer, 11 Dec 2012.
  1. BGEngineer
    BGEngineer
    13 Oct 2008
    117
    Thanks Received:
    7
    London
    Country:
    Hi. I am in the process of renewing my halogen lamps to LED and its not as straight forward as I had hoped!
    Looks like there are so many variables ie wattage, number of LEDs, colour shade (cool white to warm yellow), intensity (1000K, 2000k, 3000k...). Anyway got my head round most of it but am not sure as to what beam angle to go for.
    There are lots of sites that describe the beam angle ie 40o to flood the room and 25o for more of a spot. But I just wondered in your experience which looks the best. I know different situations call for different beams, but is there any you would avoid?
    I am replacing the kitchen and lounge ones. Many thanks.
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    The wider the angle, the larger the spread of light, depends what you are after.
    If you wish to spread the light more evenly over the location/area or if you want to have a more direct beam.
    Totally up to you
    Unfortunately the use of down lights was not originally for the domestic sector and they were designed to highlight specific areas, rather than spread light, but they are very popular now in the domestic sector.
  4. securespark
    securespark
    11 Jan 2004
    37,138
    Thanks Received:
    1,288
    Country:
    If I can just cut in here- what would folks recommend for an LED GU10 these days?
  5. ricicle
    ricicle
    14 Sep 2006
    6,343
    Thanks Received:
    382
    Gloucestershire
    Country:
    These are good.....
    • Thanks Thanks x 1
  6. 17thman
    17thman
    29 Jun 2008
    834
    Thanks Received:
    46
    West Midlands
    Country:
    • Thanks Thanks x 1
  7. BGEngineer
    BGEngineer
    13 Oct 2008
    117
    Thanks Received:
    7
    London
    Country:
    Thanks for the replies.
    I have gone for the Phillips master 7w 3000K 25o beam in the kitchen and they look really good. Has instantly given me that clean crisp light look very atmospheric. I am going to go for a wider beam in the lounge to get a bit more of a flood lit effect. Thanks
  8. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    "Atmospheric"?
    FGS man - A KITCHEN IS A PLACE OF WORK - you don't want atmospheric you want uniform and bright enough to be able to work in there.
    Do you think you'd ever get narrow beams of atmospheric light in a commercial kitchen?
    :rolleyes:
  9. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    I think he is referring to the light quality and colour, as the philips LED's are a really nice light, irrespective of your opinions on LED/Halogen spotlights
  10. Sponsored Links
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    OK - do you think that you would ever get any lighting in a working kitchen which could reasonably be described as "atmospheric"?
    I know that the term is imprecise, but if you asked a lighting designer for "atmospheric" and he delivered what was appropriate for a kitchen you would almost certainly have words with him.
  12. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    Yes, definitely. I would count most under cabinet lighting 'atmospheric' I would also describe plinth lighting as 'atmospheric'
    Plinth lighting is, admittedly designed for effect, but cabinet lighting is both atmospheric and functional. Haven't seen it much, but over cabinet lighting is also 'atmospheric'
    [​IMG]
    Can't tell me that kitchen isn't atmospheric. Just cos it ain't fluorescent doesn't mean it's not a valid method of lighting
  13. securespark
    securespark
    11 Jan 2004
    37,138
    Thanks Received:
    1,288
    Country:
    Thanks rice & 17th. Have either of you used these lamps?
  14. 17thman
    17thman
    29 Jun 2008
    834
    Thanks Received:
    46
    West Midlands
    Country:
    secure, i have used the led hut ones that state a 120 degree beam angle. I cant pretend to tell you exactly how that beam is measured in terms of lumens per degree and because of the envelope of the lamp face, i dont know how that can be acheived, but they give a more noticable ambient light than others i have used, if that is what you are after. I am not a fan of downlighters for general room lighting however.
    • Thanks Thanks x 1
  15. securespark
    securespark
    11 Jan 2004
    37,138
    Thanks Received:
    1,288
    Country:
    Thanks. I've ordered some of those. I'll let you know how I go with them.
  16. ricicle
    ricicle
    14 Sep 2006
    6,343
    Thanks Received:
    382
    Gloucestershire
    Country:
    Yes I use them at work and have them in my kitchen on a spotlight bar.
    • Thanks Thanks x 1
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
