led bulb for bulkhead pir
  • Thread starter Thread starter ih
  • Start date Start date
ih
4 Nov 2006
London
hi
just bought couple of bulkhead pir lights without bulbs.instructions are use max 60w es lamp.(e27)
the luminare is compatible with bulbs of the energy classes A to E
1.can I use led bulb if so what watts ?
2.just for my knowledge will this light work with CFL lamp ?
thanking in advance
P.s. the bulkhead is with plastic diffuser
1. unless it states not to then any e27 should be compatible - he only time I have known issues with LED is when a dimmer is part of the PIR and the LED buld is not dim compatible. As for wattage anything up to 60 watts. I think I put 4 watt Diall branded bulbs that are very good replacements for 60 watt standard filament bulbs.
2. Again unless stated yes - infact I have some that have CFLs in still but most have been replaced for LED
  • Thanks
Reactions: ih
Direction may be a problem. The LED bulb is normally designed to shine away from the base. But a standard tungsten bulb shines in all directions no shaded by the base. I used a R7s LED tube replacement and the part which would normally be reflected has no light output.
imgp6604_1-jpg.95691
You can see in the picture how all the LED's shine out. It depends how the bulb is mounted but you may end up with a rather odd light patten.
  • Thanks
Reactions: ih
