I am considering fitting led downlights to the ceiling of a purpose built flat with concrete floors I.e the flat above has a slab of concrete separating it from the one below.
The ceiling void is only about 55mm so I'm a bit limited on which downlights will fit; is it ok to use non fire rated ones in the circumstance, since the flats are separated by concrete slabs?
