LED LIGHTING
  • Thread starter Thread starter sh
  • Start date Start date
sh
20 Jun 2004
I want to put 18 led lights (.7w each)in a new kitchen plinth using a toroidal transformer.Can anybody advise on wiring technique.Is it done in a 'daisy chain' fashion ?
What voltage LEDs are you using?
If you use a daisy chain (series) and one fails they all fail, like christmas tree lights. Also the, say you are using 12V, the woltage will be shared between them and they may shine dimmer.
Putting LEDs in Parallel will avoid this but you will need to use resistors to lower the voltage (always advisable).
Meblin
If by daisy chain you mean radial, yes.
It is generally not done serially, unless supplied specifically for that purpose.. Sometimes they are. Did you buy them as a kit or what?
as leds are meant to be lit by dc (transformer being ac) you may notice they flicker at 50 hz
i see no mention of rectifier, just torodial transformer (probably too big anyway)
They are 12v and using a 50Va toroidal transformer which I presume is DC, TLC say you can use up to 80 lamps using 1.5mm cable.How do I connect these ?. Radial (daisy chain) or parralel (spider)
Thanks in advance
need more info, post link to which you refer on tlc site (or part No)
standard leds are 3v not 12
standard transformers are ac
the recomended transformer is designed FOR the lights.
the lights you have are NOT single LED (which is what your origonal post implied)
wire them in paralell i.e = = = = =
as oposed to in series i.e ------------
Sorry to sound stupid ,but can you expand on the drawing.
Thanks in advance
Thanks in advance
ok.
is that better?
seriously the double lines are each of the fittings two wires (all connected to the same place) i.e you could end up with 14 wires at the transformer if you have 7 lights
the single lines are the fittings wires connected to each other i.e in to out in to out etc, so you end up with only two wires
you want the first
Breezer - don't you think that the fact that TLC quote different cable sizes for different numbers of lamps indicates that you wire them all on a single radial circuit, rather than 1 per light, i.e. :
If you were to wire in series you would need a larger power supply to obtain the same brightness.
I would say the wiring would be similar to halegon lamps that are connected to 2 wires. One wire is +ve and one is -ve and the lamp creats a link. Breezer's diagram indicated the cablesso it would look like this (is o is a LED)
-o-o-o-o-o-o-o- Series
o o o o o o o o o o o o o o Parallel
Meblin
i did say paralell but i also said all wire in one place for ease of understanding
