Hi all,
Can the following be done?
I have a 3g light plate in the kitchen of which 1g is not used. I want to use this spare to switch the plinth lights on and off but realize there is no neutral here so would the following work ? ...
Fused spur off the kitchen ring main to a suitable location
Wire in the transformer to the fused spur
Cut the wire of the transformer on the supply side to the led lights and wire this into the 3g light switch
Then wire the other half of the cut wire to the 3g switch and plug into the led as normal.
Thanks in anticipation.
