Installing new spotlights but right next to beams. Lots of room above and all around other than the side effectively on/next to the beam. Reasonable room for air circulation too.
Question is one of heat and safety. All I can see/read is that as are not standard voltage / halogen lamps which give off a lot of heat, that I shouldn't worry about LED heat as is minimal. However cannot see anything definitive but maybe that's because it's not a problem/issue.
The actual lamp fitting/case instructions provided minimum clearances for use with normal halogen but nothing mentioned regarding LED.
Is it a question of if they fit it's okay?
Thanks.
Thanks.
