What length of cable would you say is ideal for the twin and earth the back box of lighting and sockets etc? Too long means the cable gets in the way. Too short makes it difficult for a visual inspection etc. Thanks.
A length less than too long.Too long means the cable gets in the way. Too short makes it difficult for a visual inspection etc. Thanks.
After removing the outer sheath from the cable, I draw the wires to the centre of the box, then bring them straight out, and cut them two inches from the surface of the wall.
Why are you asking?What length of cable would you say is ideal for the twin and earth the back box of lighting and sockets etc? Too long means the cable gets in the way. Too short makes it difficult for a visual inspection etc. Thanks.
While you wrote "length of cable", do you mean the length of the insulated conductors after the point where the cable sheathing is removed?)What length of cable would you say is ideal for the twin and earth the back box of lighting and sockets etc? Too long means the cable gets in the way. Too short makes it difficult for a visual inspection etc.
("two inches from the surface of the wall". Before or after you strip the insulation?After removing the outer sheath from the cable, I draw the wires to the centre of the box, then bring them straight out, and cut them two inches from the surface of the wall.
Why are you asking?
Why do you care what other people find is ideal?
Read his question again:I'm glad he has asked actually, far too many DIYers cut the wires far too short, which makes replacing an accessory a nightmare.
