Let by testing
3 Oct 2006
Sussex
Is there a permisable amount allowed.
Going back to Landlord safetey check later on , stopped it yesterday due to meter letting by at a rate of about 1.5mb in a min.
Tried working handle and rechecked a few times but constant 1.5 a min by,
Advised a transco call out,left it turned off as empty property.
Customer has since phoned me back saying they came put test on and said its all fine.
So as im off back there later im just making sure as if its still letting by im going to have to charge him this time.
I am surprised that some of you are able to keep customers with those charging techniques.
We quote a fixed price and stick to it whatever we find on an LSC.
If we have to return another day to retest something then thats our bad luck but it rarely happens.
My normal procedure would be to issue the certificate listing the defects found. If the landlord then wanted to have a new clean certificate then we might charge again but probably would not in most cases.
I was once fooled into thinking that there was let by but in reality it was a mostly blocked test nipple on the meter. That may well be the problem you found !!!
Tony
Not telling you how to suck lemons but here we go.
Let by test:- Raise pressure to 10mb and observe for 1min. I pressure rises by <=0.5mb then OK, if more than 0.5mb then valve letting by.
Disconnect meter via outlet union of issolation valve and apply LDF, let by if bubbling.
dont forget to wipe off LDF. :wink:
Been back and whatever they did its rock solid now,he had even managed to get a cloth on the hob i moaned about being so grease coated.
edit ,
went back as with it letting by at that rate i hadnt completed a soundness test and i cant for my peace of mind let that happen.
Agile is right, at least a couple of times a week transco mates moan in the cafe about people not realising pressure carries on rising on letby caused by a partially blocked nipple ad calling them out.. The other favourite is the govenor must be bol##xed as it blew the water out the gauge.
According to the new Corgi book permissable movement has changed to 2.25 for water and digital U guages or 0.2 if the guage as only one decimal point
gotta love em
Also could have been the grease in the ECV needed a bit of moving around too, had that before.
scatmanjohn said:
:shock:
I Kid not scat
Just got isssued with the new CORGI book and guides and in the Tightness testing one it lists the permissable movement as the above
also on u16 meters with pipework 28mm and lower you only have a 1 mbar drop with no smell of gas
ALLL CHANGE
AGAIN
corgiman said:
scatmanjohn said:
:shock:
I Kid not scat
ALLL CHANGE
AGAIN
I kid you not corgiman if that was the case then why bother with a let by, on a tightness test a 2mb would show as a sound test, and on new pipework with no permissable drop :?: :?: :?: :shock: :shock:
ECV letting by at 2mb over 1min test, this would show as a sound tightness test on pipework that actually has a drop of 4mb over 2min test period.
Really if you've got the new CORGI books and it says 2.25mb ok, then surely it must be a typo :?:
Get it right clf-gas
You do not raise the pressure, you reduce it to 50% of the operating pressure.
