Let shower tray into wall?
19 Feb 2009
What are the benefits of letting a cast stone shower tray into the wall on a stud wall?
A free shower downstairs?!
Unless you need the space it's not a grerat idea. You'd need noggins to stop the wall board flexing. Movement is the enemy - so is plasterboard, use something waterproof!
Thanks Chris, just out of interest would you let them into solid walls?
And is this done to minimise leaking?
Just one more thing, if shower tray/enclosure is going against a newly plastered wall (NOT dot & dab), does it need aquapanel behing the tiles?
Or is aqualpanel only for studwalls?
Not unless I was short of space; the tiles should overlap the tray & that's enough. The way to prevent leaks is to do the job properly using the correct materials. :wink:
No.
Primarily but you can use it on solid walls to provide a flat tile base if the wall is in a real mess & you don’t want to (cant) sort it out with plaster.
Ah? So you don't need any aquapanel or tanking when the walls are solid. Makes sense, I'm only using a Mira Sport anyway.
:lol:
:lol:
I would say not. Aquapanel is cement based, much the same a solid plastered wall, water resistant but not impervious; there are some, even more fastidious than me, that would say always tank but, IMO, you won’t need it in a domestic environment unless it's a wet room. :wink:
