I have removed some tiles in my bathroom, whilst removing the tiles it has pulled off some of the original skim coat plaster in places so I have some plaster and some plasterboard showing.
My plan is to fill these shalow areas (3mm) and any minor imperfections with a pass of MAPEI RAPID-SET WALL & FLOOR ADHESIVE, to level everything out.
Its a Rapid-setting flexible adhesive.
And then use the same to attach the tiles once it has dried.
Is that feasible?
I plan to use MAPEI plaster primer on the remaining plaster and what is showing of the plasterboards prior to filling.
Do I need to prime again before tiling with the same adhesive and if so do I use the same primer?
Any help appreciated
Is that feasible?
