hi, I need to level off a 4x12metre room, at the moment its quite uneven with slabs and a concrete slab. Its hard to say but I think upto 20mm in places. Everywhere I read says screen should be minimum of 50mm or thereabouts. Self leveling compounds look extremely expensive. The floor is unlikely to be damp proof, so I'll start by laying 1200guage membrane down.
Could I then lay a 20mm screed across the entire floor, this would likely be 10mm in places and upto 30mm in others?
I want to be able to finish with wood either laminate or planks. At the moment the ceiling height is only 210cm so not much room to play with.
cheers.
cheers.
