I would probably use 3 or 4 but at the end of the day the screws are only really there to keep the two bits of chipboard together until the glue dries.
It will only squeak if one moves against the other or the fixings, if you use nails, becomes slightly loose.I would probably use 3 or 4 but at the end of the day the screws are only really there to keep the two bits of chipboard together until the glue dries.
Thanks.
Just one further question regarding the 'chipboard under the join of the existing/new flooring' method - is there a risk in doing this that the chipboard that sits underneath the existing (and new) flooring will squeak by rubbing against the existing/new flooring?
But you would trust the T & G around each sheet to take the same weight without the risk of it de-laminating which is just glued whereas the suggestion was to screw it as well?....think I'd stick with the softwood noggin! Chipboard is a b*****r when it de-laminates, I would trust it at all by adding that flange to take any weight.
Nozzle
All what ifs. What ever is suggested you respond with a what if!!If we went with the 100mm wide strips of chipboard glued to the bottom of the existing/new floor, then if the glue ever weakens / the two boards become loose at any point, would the existing/new chipboard on top of the 100mm chipboard then start squeaking? Or to put it another way, if glued correctly, how high a probability is it that the 100mm strip on the bottom ever becomes loose (and therefore becomes prone to squeaking)?
Join two small bit of board about 2ft square the way I suggested secure one and see then try to break the other away. Now take another couple and just glue them by the edges as you were asking. Pick one up hold it horizontal and are they still stuck together? Answer your question?Can the join of the new flooring to the existing be done by leaving say a 2-5mm gap between the existing flooring and new flooring and filling this gap with e.g strong adhesive? Or is this a complete no-go (if so, why?).
It's a floor in a house. Why not lay one level of boards one way and then a second layer on top would that be strong enough to keep you happy?
