Can anyone give me tips on the easiest/neatest way to lift tongue and groove floorboards. I am planning on having my boiler replaced and want to renew all pipework and rads myself so a lot of boards will need to come up. Any tips please.
For a puker job you need to go to the wall, remove the skirting and lift the first board, the rest of the boards should now come up fairly easy using a board lifter, right back to where you want to lay your pipes. be carefull to cut notches for pipes over the span of a board and not a joint. keep your cuts in joists to a minimum and mark the boards when you replace them, to show the position of the pipes you have laid and any other services you may have found, ie wires or gas pipes, if you are leaving the floor boards exposed then do this on a sketch
