hmm, i guess being a cupboard the lamp isnt used for long periods? In which case a standard filament lamp would be better - low energy lamps dont like being switched too much.
Also, is there steam in the cupboard from baths? this will affect low energy lamps, with their sensitive electronics.
Aside from the environment, take teh back off the lampholder and check the connections are tight.
