Replaced an old light fitting in the hall with a new one....managed to blow a fuse when switched power back on (think a wire had slipped out).
Changed fuse wire, re-fitted new hall light............bingo - new hall light now works.
Problem is, the light in the kitchen no longer works - was absolutely fine until I fitted the new hall light! (All other lights in the house are working)
Suspect I need an electrician but any other suggestions greatly received!
________________________
moderator
moved as posted in wrong forum
moderator
