I want to change a light fitting. Its the actual fitting the bulb goes into. Do i have to switch off at the mains or is switching it off at the wall good enough?
Turn it off at the consumer unit!! Also - double check that the power is off with a volt meter. Note down exactly what goes where before disconnecting anything too - maybe even take a couple of photos.
