I have recently been replacing brass (effect) sockets and light switches with stainless steel types. During the course of the changeover I have come across a few things that I would like some advice (cannot find specifics in the Wiki)
1. Kitchen/Utility. In replacing the last 2 gang 2 way switch which controls a. the utility room light and b. the outside light I found a wire on the old switch bridging terminal marked 3 on one gang to the common terminal on the other gang. Copied the wiring exactly and switch works as expected
This is something I have not seen before and I can only assume that this is a borrowed live - is this correct?
2. In replacing all the switches I noticed that no earthing made to the switch itself. Earth connections on all back boxes.
Is it safe/good practice to rely on the screw to back box for earth connection or should I run another earth from the back box to the switch earth?
3. Conservatory. About to replace the light switch in this area and found that the switch is actually double pole. Main feed into the conservatory is from the downstairs ring main with a fused spur to the lighting (comprising 6 x 50watt spots). Is there any reason why I cannot replace this switch with a standard single pole?
