Hi
I'm just planning some wiring for my flat and have a couple of questions:
Lighting:
Since I'm going to sell the flat on and buyers love halogen spots, I'm running spots throughout, using spotlight runs from junction boxes (8 spots in living room, 6 in bed 1, 6 in bed 2, 4 in hall, seperate circuit for bathroom and kitchen)...
I plan on using Mains Voltage fire Rated GU10 spots. A total of 24 spots will run from 4 junction boxes. Although I have checked load etc, I read somewhere that no more than 10 lighting points should be serviced on a single lighting circuit. Does each spotlight count as a lighting point, or each junction box (i.e. each switched point on the circuit?)
Oven:
I'm going to put in an electric oven and gas hob with an electric pilot. The oven will be wired with 6mm 2-Core and Earth to a connection unit with a 30A fuse. I plan running 2 wires from the connection unit, one to oven, one to hob. Should these both be 6mm 2-core and earth?
Thanks!
Lighting:
Oven:
Thanks!
