Lighting circuit not earthed
R
RhysJames2008
Hi there,
I have recently redecorated a bedroom upstairs in my 1970's house. I am replacing all the light fittings, switches and sockets with chrome fittings but there is no earth on the lighting circuit throughout the house, so I cannot have chrome accessories.
My question is, what is the quickest, cheapest and easiest way I can get an earth on my lighting circuit? (Without having to bolster into a wall to lay cables in there).
Many thanks and best regards
Rhys
25 Feb 2008
Kent
Re-wire, or Class 2 fittings. I'm afraid it really is that harsh, anyway I re-wire is probably overdue by now.
18 Oct 2006
Staffordshire
In a 70s house you may not have solid walls, if so you may not need a bolster to add a neutral.
22 Jun 2005
Birmingham
He's already got a neutral, he needs a cpc.
I am surprised that the installer failed to include an earth, only houses without a cpc that I have seen were wired in the 60's.
You may be lucky and could find the cables will pull the new ones in. remember to only pull cables up to prevent debris in the cavity jamming the cable.
12 Jan 2008
Essex
I am surprised that the installer failed to include an earth, only houses without a cpc that I have seen were wired in the 60's..
Are you Sure that the earth is not simply cut back short for some reason
