I am trying to install six 240v downlights all switched from one light switch. I am a little bit lost at the moment. How do I wire this??? any advice in plain English appreciated.
Once you have taken the above in, you will require to use a cable that can handle the current being drawn under load, normally 1.00mm T&E is suitable for a circuit being protected by a 6A breaker.
The instruction may suggest omitting the CPC/earth cable at the fitting, this does not mean omit it completely, keep it continuous around the circuit even if not connected to light.
Certain techniques must be conformed to when routing cable such as safe zones, chase depths and holing of joists.
Also requirement for RCD protection must be researched.
Also inspection and testing required for minor works.
