.... however, be aware of the fact that, if you were to run a separate earth to the light fitting (from wherever) as a single-conductor cable, unless that cable were 'mechanically protected' (which it wouldn't be) it would have to have a minimum size of 4mm².
Kind Regards, John
Kind Regards, John
How do you know it's not protected ?
DS
Argument for argument's sake I'm not a betting man, but if I were ... !!!How do you know it's not protected ?
Hi, no it does not have to follow the supply cable or go back to the CU, you can pack up an earth from another lighting point. If you have a continuous cpc in the supply cable is it not possible to extend it?
Regards,
DS
Sorted... Managed to dig the cable out of the glue and get a connection to the earth wire... Thanks all.
