Hello and thank you for reading this message.
In a kitchen ceiling there are normal recessed spot lights. They're about 15 years old. Here is a link to a photo looking up through the ceiling finisher into the light unit.
https://www.dropbox.com/s/cilaxyo95sp6e29/light fitting.jpg?dl=0
Some of the units are not working and it's not the bulbs. Someone who lives in a neighbouring house says that part of the light fitting gets burnt out eventually. However from the photo there isn't an obvious problem.
Also, the units are the sprung type which push up through the ceiling hole with the springs then holding the unit in place. But the unit will not come out it appears without forcing it back down out of the hole which will probably break the springs.
Questions are:
1) Is there a known cause for these types of units to "burn out", and if not what could the problem be?
2) How do these units come out of the ceiling?
Thank you again for reading.
Questions are:
