I have recently built a double 'outbuilding' ... I now want to fit
fluorescent lights in each 'bay'
As the ceiling is not boarded - open trusses, there will be no reflection
downwards of light off a ceiling.
I intend using IP65 weatherproof versions, ... anybody know of a guide or even of freeware to calculate, how many & what size I will need.
Floor area is :
In one bay - 2.54 x 8m \This bay has walls on 3 sides - open front, used as car port.
This also has a cross wall providing a 'shed' at one end taking 3m of the 5m run.
And in the other bay.... 3.75 x 8m
This is open at front and one side (wall is post & gallows brackets construction)... and is used as a 'boat shed'
Floor to truss joist is 2.32m
I could fit lights up 100mm or so higher than the joist, so that angle of
dispersion is slightly improved, but if I fit them higher than that the
trusses will cause too many shadows.
Guestimate is to go and fit 2 x 6' double fittings at 1/3rd in from each end in each bay ... but no details to support this.
Read a post elsewhere that 6' fittings are becoming obsolete - but seems no shortage in wholesalers.
Floor area is :
