lights and wall lights
23 Nov 2011
i am changing my front room light for new, and putting 3 wall lights up. all to run from the same switch. question is that the light centre light has only got the switch live to it and the live supply feed to the switch,
what is the best way to wire up the wall lights to make sure they come on all at the same time?
any ideas?
Have a look at wiki-lighting, on the top header.
Are you doing away with a centre ceiling light or having both centre and wall lights?
Do you intend to have 2 switches (on for each lighting type), or one for both, or will the ceiling light be removed?
In simple terms, if you are only having wall lights you need a LNE feed to the 1st light from the lighting circuit: from that light you extend the LNE to all othe wall lights.
At the 1st light with the circuit LNE you will run a switch cable to the switch location.
That cable interupts the L from the wall lamp circuit and sends back the switched L which will feed wall light L 1st, 2nd and 3rd.
If the above makes no sense, and the wiki seems in chinese then please employ someone to do the work for you.
