lights dim when ch boiler starts up
festa said:
Festa asked...
Runci21,is your electricity supplied via a T.T,(overhead mains cables coming into your property)?
Runci21 answered...
yes it is , its an old property on a farm
So i `ASSUMED `right,didnt i.:cool:
No not necessarily. Could be an overhead PME supply.
What we are trying to say is you must not refer to an overhead supply as a TT supply.
There are lots of rural overhead pole fed supplies with PME earthing systems, just as there are lots of urban underground fed supplies with TT earthing systems.
Back to the OP,
Lectrician said:
An overhead....supply will predominantly be fed by a length of cable from a small pole mounted tranny - It is this small tranny that has a limited capacity, and high impedance, causing voltage dips on high loads. Long network runs will also give very similar effects.
There is your answer.
your nearly there, just need to shave your post writing time by arround a minuite ;)
davy_owen_88 said:
What do I win? If you find RF and steal his keyboard I'll let you win :p
You'll have to try harder than that ;)
