Lights not working
12 Nov 2022
Hi, can anybody help, one of the gu10 bulbs in my bathroom light fitting stopped working I replaced the bulb but the lights started working erratically,slow to come on or going off, I then replaced all the bulbs but none would come on so I bought another set and the same thing happened again, I have managed to get the lights working only if I have the 2 original builds fitted but I have noticed that the original bulbs are cold but the new bulb gets very hot .
The landing light by the bathroom has started to come on dim when switched on and when I switch on the bedroom light both the landing lights go very dim and sometimes both go off, when I switch on the bathroom light on both the bedroom and landing lights start working as normal and if I switch off the bathroom light they are ok ?
The bathroom light also is connected to an extractor fan.
As anyone come across this ?
Show us what sort of bulbs (preferbly the packaging)
Have you got a dimmer switch?
When were the light fitting and switch installed, and when did they last work properly?
What has been changed since?
What you have described can also occur if you have replaced switches and buggered up the wiring.
