I'm unlucky enough to be in a regeneration zone which means that there's now lots of heavy traffic in the area as houses are demolished and plots cleared. It also means that, as soon as I move out, my house will also be knocked down. It's not the end of the world if a DIY project goes wrong. I wish to add a little value to the property before it is valued. I recently replaced the front window with a uPVC unit. I may have been over-enthusiastic using an angle grinder to remove the old window but, after the job was finished, a small crack appeared in the brick work close to the lintel. This has been filled and I've learnt something.
I plan to replace another window because the frame is particularly rotten and I already have a suitable uPVC unit. I am concerned though that the pattern of the brickwork is clearly visible from the outside but there is nothing to be seen other than a half-inch strip of wood that could be considered as a lintel. There is the full height of the house above. I'm obviously concerned about disturbing anything. Should I start looking for a hidden lintel and where should I look? Any advice other than employ an expert would be welcome. tia.
