Hi all,
I want alter the kitchen of my 1930's semi. The left side wall is the internal wall; the right side wall is the external wall along the side of the plot. The kitchen is 2.7 wide at the entrance, and 4m deep. It narrows down to 2.3.m on the opposite side (the garden wall). This reduction starts when you walk 3 metres into the kitchen towards the garden wall; there’s unwanted brickwork on the left side wall. The remaining 1 metre of depth projects into the garden and has a sloped tile roof (there is no first floor load over this section). The bathroom is directly above the main section of the kitchen.
I would like to make the kitchen into a true rectangle. So I gather the existing lintel/timber support will need to be removed and a new RSJ put in for the full width of 2.7m opening, and then unwanted brickwork removed, and new walls built up.
There is also a hearth chimney (on the right hand side wall) that I want removed. Its 1.5m wide, and has 90cm wide opening in the middle. It projects into the kitchen by 25cm up to 1.5m, then only 10cm above that. From the outside you see it coming out 30cm for the full height of the kitchen, and then there’s a narrow chimney stack that is built up from the top of that, going all the way of the external wall.
So my questions are:
1) How does a builder support the first floor whilst removing the old support? Web sites show builders using needles to support brickwork. Would that be applicable here? Would the sloped roof need to be undone?
2) How is the lintel supported by the side walls? Will it need to be rested on load spreading blocks? The walls are 2 brick courses thick. Does a lintel requires a min 6 inches resting on bricks?
3) Is there any need to reinforce the walls in any way at the base (i.e. under the floorboards)?
4) Is there a need for a lintel in place of the hearth chimney (I only want to remove the brickwork within the kitchen)?
5) Is this a tricky job to undertake? I have repeatedly asked three “reliable” builders to quote me; none of them have even visited. I would be very grateful if someone could give me a reasonable ballpark price for this job?
Thanks in advance
Thanks in advance
