- Joined
- 31 Jul 2016
- Messages
- 18
- Reaction score
- 0
- Country
I am considering raising my kitchen/outhouse roof as it is too low.
The ceiling height is just over 2 metres, it is original but i think it used to be a toilet and something else, coal shed perhaps as that is what my neighbours looks like, my neighbours is divided in two lengthways, where mine is one room and part of the kitchen.
The house was built in 1938 has a cavity which is probably only just about an inch and a half possibly a bit more wide!
It currently has a lintel which looks too narrow but i guess it is fine? as it looks old and there have been no issues!
I would like to raise this up, im looking at replacing with a 195mm wide I Beam ITG lintel or something similar? due to the cavity width, which seems to limit my choice to solid wall lintels or should i do two separate lintels for each leaf, this is on an external normal two floors semi detached house so is a load bearing wall
I also want to remove a return on one side as it is on the long back wall and not at a corner so the lintel would need to be bigger hence having to purchase a new one
My main concern is to achieve the minimum 150mm bearing surface on the side wall (it currently is just under 150mm) i would have to corbel slightly into the cavity and im not sure if i can do this within building control, it is not a well controlled cavity as there are lots of it that are filled with rubble that is trapped as i found when renovating my bathroom and a few windows!
I want to sort all the facts out before i go to building control as i may leave it where it is as there are to many potential issues, but just raise the roof anyway by approx three brick courses
Any help would be appreciated
