How much load can a breeze block take with the correct fixings?
I want to attach some 3m steel steel box section running parallel, offset around 1m away from the wall, attached at each end (unsupported in the middle). Complete weight of assembly including brackets, bar and the load it's designed to carry would not exceed 100kg. The bar will span across a door way so there can be no risk of it falling off and landing on someone. Setting the ends of the bar into the side walls is a non starter as the walls are spaced too far apart.
Is it possible?
Is it possible?
