Hi all,
My boiler ( with Sterling burner ) started locking out from cold.
Pressing the reset button made the motor run etc but failed to ignite and obviously locked out again.
The only way I could make it run is by pressing the reset button and then turning the stat/on/off rotary control fromOff to on about 4 or 5 times.This stopped it from locking out and sort of forced the ignition. Once it fires up it will continue running normally until it's time for the programmer to switch it off.
I had the local engineers round to look at it and the said it was out of adjustment and that a service would probably fix it, he also said if it locks out again it would probably need a new nozzle. They serviced it and it continued locking out, so I called them again, this time a different engineer came ( same co ) and he tested it and said it was running weak. So he re-set it up.
It ran fine for a couple of days and then locked out again.
I called them and said " in my opinion" I think it's the control box thats faulty. Due to the fact that me turning the switch on & off will cause it to fire. I think the control box is failing to switch on the spark.
They said to me " we think it could be a faulty control box " and that they will get one & try it.
They appear to be the sort of firm that dont want to waste money on parts that may not be needed - fair enough but when a control box can be bought for under £40, I'd rather just get one !.
Whats your expert thoughts on this ?.
