Locksheild valves all wide open - anybody know why?
15 Nov 2006
Devon
New house new Ariston A30 MFFI combi-boiler fitted.
4 rads downstairs - cloak hall lounge x 2
5 rads 1st floor - 2 beds bath ensuite hall
1 rad 2nd floor - bed
Anyone know why the engineer would leave a system with them all wide open. Is this best practice now?
Thanks - from muddled
This is new build so the installer does not bother as no one is checking his work and he was paid before anyone moved into the house.
There are still many nupty installer who genuinely believe that you dont need to balance a system with TRVs.
Balancing is only needed if the system doesn't perform as spec.
If all the rads get hot and they have TRV's where's the problem.
Throttling the return valve down also makes the system noisy so the LS valves are better fully open. :roll:
Numpty. Hmm.
There are still many registered gas fitters who don't do plumbing, even on heating systems, and who don't know that the word "don't" contains an apostrophe.
A well designed and correct pipe sized system should not need balancing
Numpty or no numpty . Can anybody show me how to balance a system using trv`s,after 25yrs of installing maybe this is where i`m going wrong
Roll it and smoke it :shock: :shock:
Oh this should be good.
So, how would you go about sizing the pipework for a system with the nearest radiator having 4 metres of pipework to/from the pump, and the furthest one having about 30 metres of pipework to/from the pump, given the objective of all the radiators and rooms heating up at the same rate, as far as is possible?
The original poster asked a very reasonable question. We then end up with very abusive posts when a reply is provided. Whether right or wrong surely we should not treat those who present an opinion in this way and surely everybody else who might wish to know the answer does not want this kind of behaviour?
is to see people mislead novices by posting b*llocks
Sorry if you`ve been misled
You open all the TRVs to full and balance it just as you would balance a system without TRVs.
Balancing sets the temperature differential across the rads ensuring a condensing boiler is working near maximum efficiency and well as enabling the rads to all heat up at roughly the same rate.
Thanks Agile - I have gone against contradicting advice from Screwfix forum posters saying to leave alone unless rads dont get hot.
However - the upstair rads got hotter quicker which is exactly the opposite what I would like. So have turned 1st and 2nd floor lockshields down. Much better now - perfectly balanced.
My thoughts were that gravity and longer pipe runs were delaying the time taken for the lounge to heat up
wall hung combi on kitchen wall
ground floor rads 1 metre lower
upper floor rads 4 metre higher
My conclusion is that even if all rads eventually "get hot" adjusting the lockshields has brought benefits to my system.
Therefore thanks Agile
Hi ajstone - its me omidknight popping up to comment here and there
Hi R**
I saw your post when up pops Mr nasty again :roll: let him get to me this time.
