Yes, they were turned off for decorating, and now leak in the open or closed position, I don’t want to rip open a grands worth of decorated lounge to access the pipe work properly to I’m looking to replace just the internal threaded insert part of the lock shield
If it's a combi boiler, then shut down all the rads at both ends, release the system pressure and you will probably be able to replace the valve with minimal water loss.
I would recommend native 10mm valves or internal 10mm reducers that use an olive not the 'snap' type, be prepared to cut off and replace the old olives and nuts.
