loft boarding project
5 May 2009
Newcastle upon Tyne
ive just had my loft insulated and want to board it out i had a look at b and q and they have packs of boards 3 for under £5 but they are only 32cms wide so i think it would take a lot of boards. when the guy came who was doing the insulating he said if i want boards in the loft i cant screw them down i just have to lie them on top as the ceilings could pop due to the compression. i have a lot of stuff to keep in the loft so need the space for storage. the loft hatch is old type and only 21 inches wide so i was thinking would it be possible to make the loft hatch bigger and fit a ladder aswell. is the guy telling the truth that boards cant be screwed down or is there another way of boarding out my loft. any advice would be helpful thanks
dont like the sound of lots off stuff
you should only lightly load the the loft assuming its 4x1.5" or simmilar
if its solid like foam then it will pop the ceiling
if its easily compressable [compresses under your mobile phone for example]then youll be ok
dont forget your boards can go through the diagonal on the hatch
