Loft conversion
7 Oct 2008
Cardiff
Hi
Im planning on doing a loft conversion what size floor beams should be up there
start by telling us the span between the load bearing walls.
are you going to draw up the plans and calculations yourself, or get an engineer to do it?
you'll need them for the Building Control application.
and is that the answer to the question "start by telling us the span between the load bearing walls. " ?
you mean, this is the maximum span between load-bearing walls?
It appears that way
there is the front window then 3mtr later there is a wall then 3mtr later there is the back of the house
