Loft lighting the best way forward....
30 Aug 2011
Ipswich
Hi, I have to oak beams that run the length of the house in my loft, I am looking to have some hidden down lights behind both beams (3 behind one long beam & two behind the other beam because the entrance is in the middle). I was thinking of putting 5 spotlights 50 watt each on mains 240volt, this would have a dimmer switch to lower the light level (as its more of a soft light I want). What is the lowest watt bulbs you can have connected to the mains? Would I need a high voltage dimmer switch? and are spot lights Ok to be used on a dimmer?...... The other option would be not to have a dimmer but have a transformer behind each beam and maybe have decking still low voltage lights. I worry about this second option because LED style lights tend to wear out after a few years (like my decking lights have). Any suggestions / advise welcome....
Is this loft a habitable room and needs feature lighting ? If not then spotlights are totally impractical for a loftspace.
Sorry should have said....Yes its a lof conversion. I have the main spot light fitted already, but I'm now looking to fit soft down lights behind the beams. The wiring is all sorted up to the beams, just need to decide what lights to use and what switch / dimmer to use.
What sort of lighting does the loft currently have?
I would have thought spotlights totally unsuitable for lighting a loft.
So you're deliberately putting in lights which are too bright and then dimming them...
I think you can get 1-2W CFLs
I don't think they make them. ;)
//www.diynot.com/wiki/electrics:voltage-bands
If you dim halogen lamps they go black and have a shortened life.
Extra-low voltage.
And an xW ELV lamp is just as bright, or even brighter, than an xW LV lamp.
Fluorescent strips.
Does it do a good job of lighting up the entire space?
Fluorescent strips - they'll be hidden, remember....
Fluorescent strips on a dimmer.
Goind to go for low voltage LED lights 1.3 watt on normal switch. 3 on each beam....... The truth is I was amazed at all the product on the market these days that was not available 6 or 7 years ago!.....Thanks to Everyone for Help and pushing me in the right direction :))
