- Joined
- 3 Feb 2011
- Messages
- 1
- Reaction score
- 0
- Country
We have a problem that at the moment I can't fix..............we have a double dimmer switch in our loft conversion bedroom and it is linked to a double rocker switch at the bottom of the loft con stairs.
One dimmer controls 3 x GU10 downlights 50 watt in the main room and the other dimmer swiitch controls the GU10 downlight at the top of the stairs - also 50 watt.
The original sparky installed a double dimmer that clicked as you turned it somewhat defeating the object of having it next to the bed because it was actually kind of noisy and clicky. We swapped the dimmer for a model that was silent as you rotated the knob to dim the lights. It works perfectly with the 3 ceiling lights. But when we dim the single light above the stairs it starts to flicker manically as it is dimmed and is quite fit inducing !
What should we fit that is quiet when turned and can cope with dimming one spotlight please? thankyou !
