HI there!.
I am wanting to install a log burner, I have chosen an 8kw burner, and was hoping to install myself. (i have a roofer willing to go "up top" and put in the top plate/clamp flexi flue and new chimney pot)
I understand most of the regulations, and have read the manual thing from the council ([part J i believe?) however, im a little slow
and could use some clarification please!.
We have removed the gas fire, and enlarge the hole it used to sit in!, This is now open with an opening of width of 635mm and hight of 680mm (but not inside fire, this is only to the tiles measured on the outside!)
I understand that to comply with building regs, i need a hearth size to add 150mm on each side of the width of my burner, the burner would be 400mm (meaning hearth size of 700mm?), and obviously my opening is not capable if housing this size hearth!
so coming to my question!, would the extra 65mm im missing matter? as the burner would be sat next to two non-combustible walls? or is it set in stone that it must be 150mm each side? or is this 150mm only each side of the opening of the burner? (as in the front of the burner needs 300mm in front, and then 150mm each side of that 300mm) (sorry im so confusing! well done if your keeping up!)
right the next question!
Is there any regulations in regards to the height of the unit? or can teh top of the log burner be all that can be seen (for example, seeing no ridged flue? and then obviously there would be the ridged flue and registry plate futher up the chimney!) but i dont really want to open up the height of my chimney any futher (the lintel is more or less right above where i opened up to!)
anything iv missed?
phew.
anything iv missed?
phew.
