London double glazing supply only
11 Jun 2013
London
hi
Does anyone know where the cheap double glazing supply shops in London are
Somewhere like Toolstation or screwfix but for double glazing
Seems like a minefield out there of thieves
Where in London are you?
That is fairly important,they cost to deliver,Plenty of window manufactures in and around london.
Some supply only companies will send out a technical person to measure and select the correct products that your installer can fit and your installer can register with fensa.
Prices will vary considerably,so will quality.
Are the new windows for a flat ?
Hi
No they are for a terraced house - I live in North london
Any names that can be usggested?
Have you used these guys before? https://www.modernupvcwindows.co.uk/
They seem to create their own so its difficult to compare quality to other makes
I haven't used them before but thought they had a good website when I was looking into prices etc.....
Most UPVC manufacturers will buy stock extrusions from X Y Z and fabricate the windows to suite your given sizes.
Wickes sell UPVC windows if you were not looking for a specific size and were building from scratch so could accommodate whatever size or thereabouts that you liked the look of. But as you are retrospectively fitting I doubt this will be of use unless your windows are the stock sizes.
I know a place in Romford which I would recommend having used them before if thats no too far for you, they're called window tech trade.
Email the sizes over. I do supply only to London. Ok merging or rehau
